1 - 10 of 10 Posts
The only difference I can tell is that there's a slight "chirping" noise when I lightly press the brakes. I can't tell where it's coming from. Would brake issues set off a CEL?<p>In to the dealer on Monday.
Re: CEL came on (frankhoffy)
Answer to your question <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p><A HREF="http://forums.swedespeed.com/zerothread?id=61228" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61228</A>
Re: CEL came on (s60rdood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>s60rdood</b> »</i></TD></TR><TR><TD CLASS="quote">Answer to your question <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p><A HREF="http://forums.swedespeed.com/zerothread?id=61228" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61228</A></TD></TR></TABLE><p>The CEL must be coming on for a different reason then. Maybe as simple as the air filter needs cleaning...
Frank -- mine went away after a few days ---good to go, unrelated I think. Do you have a code reader?
Re: CEL came on (blf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>blf</b> »</i></TD></TR><TR><TD CLASS="quote">Frank -- mine went away after a few days ---good to go, unrelated I think. Do you have a code reader? </TD></TR></TABLE><p>Nah, haven't invested in one yet. I should probably get one of those performance meters that also reads codes.<p>I think my car is getting jealous. I just ordered some Bilstein shocks for my truck...
Frank, does a message come up? <p>I recently had a "Brake assist service required" message. Cleared the code with my scanner and it hasn't come back yet.
Re: CEL came on (llabahn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>llabahn</b> »</i></TD></TR><TR><TD CLASS="quote">Frank, does a message come up? <p>I recently had a "Brake assist service required" message. Cleared the code with my scanner and it hasn't come back yet.</TD></TR></TABLE><p>Nope no messages unfortunately. I will take it in tomorrow to get it diagnosed.<p>While I'm at it, I'm going to see if they can fix my brake squeal, even though I have aftermarket brakes: <A HREF="http://www.alldata.com/tsb/Volvo/1112169600000_1118818800000_TNN51-09" TARGET="_blank">http://www.alldata.com/tsb/Vol...51-09</A>/
Sure enough, the light went out this morning. I think it was just bad gas, because it was idling pretty rough when cold also.<p>This is the second time this has happened in this area. Have the stations been watering down their gas or what? I've never had a problem at Texaco or Chevron. Exxon or Safeway gas, however...
Re: CEL came on (JOSBRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JOSBRO</b> »</i></TD></TR><TR><TD CLASS="quote">Had you previously had a "Gas Cap Loose/Open" message a while before the CEL??</TD></TR></TABLE><p>Nope, no messages
1 - 10 of 10 Posts
