I am trying to replace my CBV with the Forge one. The three screws holding it are old and one is stripped so I wanted to replace them. Volvo didn't know what I was talking about and the only solution they had for me was to buy a new turbo and manifold. Lol
I believe the size is a torx 30. Anyone know the exact size/specs so I can find it at home depot or somewhere. Where can I get it from?
If one is stripped, grab one of the other ones, any hardware store should be able to tell you what it is if you give them the example. Then you know the thread and pitch (10m x 1.25 for example). My local Ace Hardware carries torx fasteners, I'm not sure what your local variant might be. Switch everything to Allen head?
The actually might be Allen heads and probably stripped since I used torx on them. Going to home depot and Canadian Tire now
Don't bother with the Allen heads. Switch them to bolts so you can get a wrench in there. I forgot what size when i did it
Sent from my iPhone4S using Tapatalk while on the toilet.
