1 - 2 of 2 Posts
I am behind on my maintainence, but I would like to get everything caught up. I have 91K miles on it. I just replaced the timing belt and tensioner. I need to flush my radiator and refill. I also was thinking of having my transmission power-flushed and filled with synthetic fluid. I also need to replace the serpentine belt and the hoses. Other than the things listed above, what else should I consider doing to get my ride caught up on maintainence and ready for the long haul? Any advise is appreciated.
Thanks!
Might also be time to flush your brake fluid. Check your brake pads and rotors. If you want, you can also flush the power steering fluid. Have you replaced your spark plugs, cap & rotor, air filter, pollen filter....? Check your spark plug wires.
1 - 2 of 2 Posts
