1 - 18 of 18 Posts
HI THERE ALL I HEARD THAT IF YOU REMOVE THE CAT ON THE R AND REPLACE IT WITH A MIDI CAT IT ADDS TO THE PERFORMANCE ,IS THIS TRUE ,PLEASE EXPLAIN!!!
With no cat...<p>You will increase performance.<p>You will kill baby seals.<p>You will make trees cry.
Re: (chinaonnitrous1)
HAHAHA so u therefore saying it is worth it ,do u have to replce the cat with a midi cat tho ?
ummm im pretty sure the negatives outweigh the positives in his post. dont remove it. get a downpipe and a catback to its not ghetto. i have never heard of anyone just cutting out the stock cat and replacing it down the line on the Rs.
Re:
No midi cat is required. You would only need a rear O2 spacer if you don't want the CEL. This is of course with going catless for off-road use only. <p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>SA-R</b> »</i></TD></TR><TR><TD CLASS="quote">were can i get a downpipe from ? </TD></TR></TABLE><p>From Swedespeeds one and only Phuz<p><A HREF="http://www.phuzzymotorsports.com" TARGET="_blank">http://www.phuzzymotorsports.com</A>/<br>
From my experience (this is driving a cat less mustang gt previously with long tube headers). The R sounds great with a race cat Downpipe, and even then the smell can be pretty bad. I don't know what it is about it and not trying to change the subject but on a turbo car the smell just seems a lot worse anyone else notice that?
Re: (Bulldog6Z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Bulldog6Z6</b> »</i></TD></TR><TR><TD CLASS="quote">From my experience (this is driving a cat less mustang gt previously with long tube headers). The R sounds great with a race cat Downpipe, and even then the smell can be pretty bad. I don't know what it is about it and not trying to change the subject but on a turbo car the smell just seems a lot worse anyone else notice that?</TD></TR></TABLE><p>No change in my smell after installing the Phuz DP. Big change in turbo spool-up and lots more turbo noise however.
Re: (adykes)
For spirited "Off-Road" driving, an OEM DP without the cat makes a phenominal difference. You can get a used/junk DP for cheap, then do the catalyst "removal" in short order. The turbo revs up quick and you will be able to pull all the way to the red-line, even in the heat of summer. You also need the O2 extender - with it, you will not get any codes. Easy swap to put the factory DP on, takes just about 30 minutes.
HASING HIGH FLOW CATALYIC CONVERTER IS WILL IMPROVE AND CAR PRO-FORMANCE!<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote">You will kill baby seals.</TD></TR></TABLE><p><b>Correct</b>: You will physically club them to death; Al Gore will not be happy.
Re: (cmurphy2266)
Al Gore invented the catalytic converter. <p>Maybe turbo cars run a bit richer, or perhaps the A:F ratio varies with boost, thus attributing to a different odor than NA cars? Either way, catless cars do stink (from experience) and will not pass emissions testing (if you have it in your area).
Re: (T5 for Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>T5 for Life</b> »</i></TD></TR><TR><TD CLASS="quote">Al Gore invented the catalytic converter.</TD></TR></TABLE><p>hmmm, I don't think he did, I think he was too busy inventing the internet. He might have though, He is amazing. <p><br>
Re: (cmurphy2266)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cmurphy2266</b> »</i></TD></TR><TR><TD CLASS="quote"><p><br><b>Correct</b>: You will physically club them to death; Al Gore will not be happy. </TD></TR></TABLE><p> <IMG SRC="http://i54.photobucket.com/albums/g97/tigaubrey/crying-indian-tear65p.jpg" BORDER="0">
I have a 3.5" catless dp. It makes baby seals and otters cry.<p>Thats why I'm going toward a 3" with cut out before the cat.
Re: (Oceans60R)
Oceans...that's from the littering commercial from the late 70's-early 80's?!
Re: (T5 for Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>T5 for Life</b> »</i></TD></TR><TR><TD CLASS="quote">Oceans...that's from the littering commercial from the late 70's-early 80's?!</TD></TR></TABLE><br>Correct! mid 70's if I remember correctly.<p>I figured if a piece of paper thrown on the ground made him cry, imagine what extra pollution like CO and HC's would do to this fella.
I had a friend do some dyno comparisons, and the differences between an aftermarket downpipe (high flow CAT) vs. no CAT at all, or a "test pipe" were negligible.
1 - 18 of 18 Posts
