1 - 16 of 16 Posts
Hello All,
I have just put on a coat of wax. Its 9:30pm and I have work tommorow..I dont know y the hell I did it
....but my question is can I leave the wax on overnight. ...or will it do damage?....thanks
Ajay
Re: Car Wax Question need response asap (desaiajay)
IMO, you got to take it off when it dries. The longer you keep on, the harder it will be to remove...
I would suggest that you go out and wipe it off and buff it up tonight!
I generally work on a small area at a time, no more than a single body panel, usually much less (so as not to let the wax dry too much before buffing). Leaving it on overnight won't likely do any harm, but you should certainly buff it before driving the vehicle or leaving it outdoors.
- Mark
Use Zaino (Z2pro). IMO it is superior to any wax (I tried them all), can be left on for long periods of time and comes off easily. I would not drive around with any product on a car, as the finish will accumulate abbrassive debris that you rub in when buffing.
Actually, for our old convertible (shown often) I will put on one coat of wax and let it fully dry. Then put on another light coat over that, and buff off. Mequires Gold Class and Griots Best Of Show both come off easily with this process, and leave an incredible depth of shine - the kind that is unrivaled from either doing it in one step. A ton of work, but the shine is so deep that on our Ford, a dog was staring at her reflection in the black part and actually kept leaning in until she smacke her head - deceptively deep reflection.
Just my 2 cents.
Re: (chong)
Sweet black grill http://********************/smile/emthup.gif
I was stupid and used turtle crap and now you can see the wax build up in the little rock chips. How can I strip all the wax off and redue it.
Re: (atlterp)
Quote, originally posted by atlterp »
Try a clay bar first.
If that doesn't work, use a FINE hand glaze, like 3M Imperial Hand glaze.
Re: (atlterp)
If you are referring to the the rock chips around the grill and bumper (painted areas) then try polishing, then clay bar, and then re-do the waxing. If your rock chips are that bad you may need touch-up paint.
I have actually liked the protection of the turtle wax hard shell wax. I usually use that as a base, and then put a better wax (P-21S) as a second coat. The turtle wax protects well and seems to out-last many other waxes.
1 - 16 of 16 Posts
