I've ad this issue since I bought it, I figured one of the things I was planning to fix would solve the problem but still no luck. Regardless if it's in gear or just revving in neutral it seems to top out at 4500 rpms, I had a tach on here for a bit to verify. Acceleration and everything feels normal just like my last 142 did.
So far I have changed out:
For your viewing pleasure: https://www.youtube.com/watch?v=bLmVfCGo0Z0&feature=youtu.be
Also I set the timing 10 degrees before tdc, the crank pully on this car looks like [10 0 10 20 30], I set the timing to the bold 10, is that correct? I ask bc my reference material was a b20 and the numbers were backwards.
The hard warm start issue is fixed and the car seems to run a bit better but still topping out at 4500 rpms, not a huge deal around town but impossible to get it on the highway when it stops at 50mph. Running out of ideas here, any help is appreciated.
- the su carbs out for a weber carb
- fuel pump
- plugs & wires
- distributor cap
- points
- condensor
