Car at 110k, have some extra cash, what do I give some love?
Guys, original owner and my 06 V70R has been a great car so far. I am normally way ahead on the maintenance schedule and was looking at what I need to do at the 110k service. Looks like I need the oil changed, brake fluid changed, air filter cartridge. Should I do spark plugs yet or closer to 150k? Should I do the PCV service recommended at 120k now? Anything else? To my knowledge, I haven't yet done any engine/trans mounts, nor endlinks or front suspension repairs except for new front struts 5k ago. I have already done the drive belt and timing belt services and the fuel filter. Pads look like they have 5mm left, so I will need to do those and rotors on the next service. What am I missing? Thanks
Spark plugs every 60K miles
Breather is up to you, only you know if it's clogged
What about control arm bushings? Those are usually gone by that mileage. Also, rear struts? Depends on your roads I guess, but mine were clunky by 80k. Timing belt? Again, I had a pulley start to disintegrate around 70k and I caught it before there was major valve carnage, but I think the recommended service interval for the timing belt is 105k (either that or 120k, but no harm in doing it early).
I was going to suggest timing belt as well but he said he already did that. In that case, my vote will always be suspension bits.
