1 - 1 of 1 Posts
hopefully here's an easy one... the tubing for the rear windsheld washer is only about twelve inches long, as in, when i filled it w/ the special green/blue bug wash, it came off the top of the reservoir, but, i'll be damned if i can figure out where the other end goes, i've taken a flashlight to it, etc, etc., and can't see where there may be a plastic connector that goes to the rear, or is this thing( the 12 in. piece of hose) just a vent, bein as, i don't see how it could pick up fluid from the container, unless there's one attached inside the reservoir... I know the pump works, as you can hear it tryin to prime up, and spit out on the back glass, but, nothng! i have already unclogged the fronts, and they work really great! i had to take off the back panel on the inside of the gate, and locktite the three bolts that hold the motor in place, as one of them was rollin around in the platic panel, and would get bounced around every time you opened/closed the rear gate. I can see the tubing @ the rear gate, as well as the plastic tubing it attaches to , to get it to the sprayer, but, lke i said, i'm not sure where to look for it up front OR, is there another reservoir just for the rear wiper?? thanks for your time, louis BTW, ths board rocks, a far as info, and links to all the good stuff on these cars! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
1 - 1 of 1 Posts
