I'm going to change the angle gear fluid and rear diff and after I change the fluids, I'm not sure if I have to pull out a certain amount back out before I reinstall the fill plug.. Does anyone with VIDA DICE know if that's the case?
They are filled to the level with the plug out. So fluid will run out a bit once filled, let it get to a drip, then reinstall the fill plug and you are good.
Thank you. My only reference was VolvoSweden on YouTube and on his car (XC70) he has to pull out some fluid and me being without a VIDA unit, I didn't know if I have to do that for the XC60 or not.
When I did mine I pulled 100ml out of the front angle gear. It may be 50ml in the rear diff..with the AOC, you fill that till it drips out and then seal it up. Correct me if I am wrong
