I am curious to know if I can add the traction control to my 850 turbo wagon. How about heated seats? can i buy the switches and heater and install them myself? Also my 850 turbo has the black handles instead of color matched. Can they be painted to look good or can i track down some color matched in white?
Re: can it be done? (jrs850tw)
Tracs, NO
Heated seats, YES. Better off with an aftermarket kit but it's STILL over $500 installed, not sure if they just sell the kit alone
No 850s have color matched handles only S70s.
It would be a PIA to do. You would have to remove them, sand them all the way down smooth before paint, not so easy with all the small curves, knooks and crannies. You might want to measure an S70s door handles, they actually may fit with a bit of work, those can be bought painted
It may look OK, it may not. I've never seen an 850 that had that done
Re: can it be done? (JRL)
Really!!! I see it everyday...ALL YELLOW 850 T5-R (hey Jeff...now you see why I want to get the black trim back on the car so bad!!!)
I thought you could add tracs; however, it was not as simple as putting a switch in. I think the ABS module needs to be swapped out and possibly more. I think the 850s were prewired for it, my 94 855 seems to be.
Different ABS modules for just ABS vs. ABS+TRACS. Maybe Victor is the one to ask about adding this.
Re: (doug242ti)
Doug is correct, it can be done. Tracs can be added. Just how much do you want to spend?
At any rate there is a guy in Los Vegas that will stuff a turbine into an 850, just costs bucks.
