Re: Can I run 235mm tires on 7.5" wide wheels? (Revolve40)
If You Look at the Spec. Chart Area When Looking at the Tires ,It will Give Rim Size Needed , Dia. of Tire & Rev's Per Mile.
I would Try the 225/50's If using 17"
On the 18" It gets Harder to get the Right Dia. , but seems
25.5 Dia. Deviation from Stock 24.9 wouldn't interfere .
I done some Traveling around Your Area , Lots of Country Rds. - Small Country Roads , Yet there are some - Nice Smooth Roads - Not as Bad as NY.
I'd Be Careful on the Low Profiles .
Modified by EngTech at 9:17 PM 6-25-2009
