Title pretty much says it all. <p>Would running say 330mmx34mm rotor ring be a problem with stock calipers/pads? New pads would quickly wear down past the point where the 2mm difference would be present but curious if anyone has run a slightly thicker rotor.
Re: Caliper/Rotor question. Running 34mm thick vs. 32mm stock. (StaggRLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote">Title pretty much says it all. <p>Would running say 330mmx34mm rotor ring be a problem with stock calipers/pads? New pads would quickly wear down past the point where the 2mm difference would be present but curious if anyone has run a slightly thicker rotor.</TD></TR></TABLE><p>Shave the pads if they don't fit.<br>When the pads are gone you will hear soon enough.
Re: Caliper/Rotor question. Running 34mm thick vs. 32mm stock. (Johann)
That's a sensible answer. Thanks Johann.
Slightly different question but does it make a difference if you run 332mm rotors on our setup? Any problems?
