Hi All,
Just got the R instrument cluster retrofitted into my 2002 V70XC. Everything works well but for some reason the speedometer is out by about 12-13km/h when checked against the GPS. Previously my old speedometer is lower by 3km/h against the same GPS unit. Got my Volvo indie workshop to check it out and they said that they calibrated it to what the car's ABS computer speed is showing on their unit. At 100km/h or about 60mph, the engine speed is 2000RPM which is about right I guess but the current R speedometer is reading 88km/h or 55mph. The Volvo indie said that it may be due to the R cluster has no stop needle to prevent the needle dropping below 0 unlike my original one which has a stop pin needle. So at rest, the R speedometer is resting below 0 almost to the odometer display.
Need your input as to how to calibrate the R speedometer to show more accuracy.
Should follow GPS input or the ABS speed unit?
Where is the optimal stop point for the needle when stationary?
Thanks.
DC
Thanks.
DC
