Trying to find the AQIS cabin air filter location on 2008 XC70, couldn't find it behind/under the glove box as on the last generation XC70, also looked under the cowl cover in the engine compartment as in some older Volvos, no luck there. Any suggestions?
Re: Cabin air filter question on 2008 XC70 (roadster675)
Hmm, ask your dealer???!
Re: Cabin air filter question on 2008 XC70 (JRL)
most likely it's just to the right af the accelerator pedal, much like the P1.<br>
Go up behind the glove box, then look left. Filter is located in the center of the car above the tunnel. You should see a plastic "door" with two clips that need to be undone. Swing open the door and slide the filter out. You will have to bend it as it comes out. Reverse for the installation.
