1 - 2 of 2 Posts
Hi there,
Local garage has diagnosed an A/C failure as at the evaporator. Any experiences of replacement here? Full dash dismantle time? Guessing it's going to be an expensive fix...
Most common problem with the air conditioners on these cars is the compressor clutch gap getting too large and not able to engage.
Does your AC work intermittently? Does it work for 5-20 minutes, then shut off and not come on again?
If that's the case, it's an easy fix.
Not sure about the evaporator, but just wanted to give a suggestion before you start dishing out big money for something you may not need.
1 - 2 of 2 Posts
