Hi guys - looking for a way to test the starter without using the ignition key circuit.
The starter is connected, and has the large red wire from the + battery and the ground, so I should be looking at the wiring that goes to the solenoid as the bypass mechanism, right?
The wire that connects the starter solenoid comes off the ignition switch, so if I need to bypass the ignition switch what does the wire to the solenoid get replaced with?
Thanks - learning but slowly here...
