I plan on purchasing a 1999 V70 wagon in a couple of days..<p>This will be my first wagon, my 5th Volvo..<p><br>Anything specific you guys know of to look for?<br>Problematic areas that I need to pay special attention to when looking at a V70 wagon?<p>It's the naturally aspirated model. 5 speed.<p>The car has 115k miles on it.<p>Thanks in advance for the help!<p>
Re: Buying V70 on friday WHAT TO LOOK FOR? problematic areas? (138)
You didn't buy it from me so I cannot help you <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
Re: Buying V70 on friday WHAT TO LOOK FOR? problematic areas? (JRL)
Haha. I ended up buying an M3 instead of an S70..<p>C'mon man.. help a brother out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>138</b> »</i></TD></TR><TR><TD CLASS="quote">Haha. I ended up buying an M3 instead of an S70..<p>C'mon man.. help a brother out.</TD></TR></TABLE><br>What do you want me to say?<br>Is the clutch OK?<br>It should be easy to push, have about an inch of free plpay and NO noises especially in neutral.<br>Leave the car running in neutral, then depress the clutch.<br>Is it any quieter?<br>If so, the throwout bearing may be going bad.<br>Does the suspension make any noises going over bumps?<br>Put it on a rack and look for any leaks o of the engine and/or steering rack.<br>make sure ALL switches work and the A/C is cold
my 98 sedan had stress fractures on the coolant tank (first inspection missed that, had to pay for it later) and one worn out upper strut mount (replaced by seller prior to sale) when I got it at 119k in early 2005. The lower engine mounts needed to be replaced shortly after, only reason the upper didn't is because it had been replaced w/ an IPD aftermarket. Like JRL said, check ALL the switches, especially the windows - I found a bad one that I had the seller replace. Check the radio display backlight, make sure that works... the button backlights are easy to replace, the display is not.<p>Listen for funny bearing noises from under the battery immediately after a *cold* start, my secondary air pump went out after the valve let water collect in it -- see this recent thread for more info: <A HREF="http://forums.swedespeed.com/zerothread?id=61889" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61889</A><p>Other than that.. the usual... service records are your friend, check oil condition, etc, etc.
