1 - 10 of 10 Posts
Buying track spec sways from IPD, how crucial is it that I get front AND rear endlinks? Just wondering if it's necessary to upgrade both.
Re: Buying track spec sways, do I need front and rear endlinks? (djkronik57)
It depens on the condition of your stock ones. The HD one are not "required" for the sways and you could always add them at a later time
You should definitely get some as stock links wear out even under load of a stock sway bar. Rear is not as crucial but definitely get the front ones.
If your mileage is high enough why not?<p>Mainly because your getting an alignment anyway, you might as well have them adjusted properly if your going with the QBM's.<p>If your using the really nice IPD Heavy duty ones, you'll probably save on installation costs.<p>If self install, you'll save youself the grief of 20 lug nuts and more..
Re: Buying track spec sways, do I need front and rear endlinks? (xman03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xman03</b> »</i></TD></TR><TR><TD CLASS="quote">You should definitely get some as stock links wear out even under load of a stock sway bar. Rear is not as crucial but definitely get the front ones.</TD></TR></TABLE><br>I recamend alll 4 i did it on mine and i cauldnt bee happer!!!
I think they are a necessary compliment to the IPD track sways. When you run IPD sways, you'll add more load to the endlinks and cause greater deflection, thus increasing the possibility of breaking. <p>
Re: Buying track spec sways, do I need front and rear endlinks? (skibum0627)
Alright, I think I'll go with the Otto parts endlinks for the front and then maybe get the rears from IPD down the line if the stock rears fail. I was just worried about beefing up front vs rear and getting unpredictable. Thanks!
Dont bother with Otto.<p>I let my order stay open for 3 weeks. No returned emails, no nothing. Not sure why the guy has his site up if he isn't checking orders.... PITA
Re: (imageomega)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>imageomega</b> »</i></TD></TR><TR><TD CLASS="quote">Dont bother with Otto.<p>I let my order stay open for 3 weeks. No returned emails, no nothing. Not sure why the guy has his site up if he isn't checking orders.... PITA</TD></TR></TABLE><p>Was this recently...it sucks, I just placed an order too. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
1 - 10 of 10 Posts
