<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by bfavre4:<BR><B>I have 46 miles currently. So all new S60s get this problem? <P>On another note that I forgot to ask in my top post, is the high beam lever not supposed to lock in place? I can only flash the high beam since it releases immediately. There are 2 high beam notches, if I pull the lever toward me one notch it releases, and if I pull the lever 2 notches it releases also. Can't lock in place.<P>[This message has been edited by bfavre4 (edited 04-30-2002).]</B><HR></BLOCKQUOTE><P>If the smell is like 'warm plastic' then you're OK. If it's really like an oil burning smell, then oil's getting on the exhaust and it's burning off. don't forget you'll be burning off the paint from the exhaust manifold for a few more miles; hopefully that's the only thing that's wrong, so you should be fine.<P>The pass-to-flash feature will only raise the beams when you pull it back. If you want the high beams to <I>stay</I> on you need to put the light switch to the 'on' position, (but then the flash-to-pass feature doesn't work.)<P>I'ts goofy, because the light switch really doesn't do anything except tell the system when to leave the high beams on . . . .<P>See the owner's manual; it'll describe how the system works.<BR>
