That message popped up on our info center screen. We figured out that it was the rear drivers side light on the bumber. How much is a bulb for that? Also, it looks like you need a special tool to get into that compartment. Is that true?<p>Thanks
Re: Bulb Failure position light? (david)
A small flat blade screwdriver used in the slot on the outboard side of the light will remove the housing. I got 2 replacement bulbs from Advance Auto for under $3 (Sylvania 2825 (W5W)).
According to <A HREF="http://new.volvocars.com/ownersdocs/2004/2004_XC90/04xc90_09b.htm#pg135" TARGET="_blank">http://new.volvocars.com/owner...pg135</A> and <A HREF="http://new.volvocars.com/ownersdocs/2004/2004_XC90/04xc90_10.htm#pg155" TARGET="_blank">http://new.volvocars.com/owner...pg155</A>, the bulb should be a W5W.<p>How to get to that area is described here <A HREF="http://new.volvocars.com/ownersdocs/2004/2004_XC90/04xc90_09b.htm#pg140" TARGET="_blank">http://new.volvocars.com/owner...pg140</A><br>I don't think you need any special tool for this.<p><br>[Corrected lamp type and pages]
Re: Bulb Failure position light? (dachshund2)
Thanks, I went to Wal-mart and bought a pack of 2 for $1.85. Now it works.<p>Thanks
FYI,<p>Your local Volvo dealer should replace it under warranty. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: Bulb Failure position light? (AFFalcons#1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>AFFalcons#1</b> »</i></TD></TR><TR><TD CLASS="quote">FYI,<p>Your local Volvo dealer should replace it under warranty. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> </TD></TR></TABLE><p>If one is very close maybe, much easier and probably cheaper to do it yourself. The cost of the fuel alone to get to the dealer would be more than the bulbs. Not to mention the time to get<br>the service guy to write it up, and the tech to spend 30-sec to replace it.
Re: Bulb Failure position light? (calridng)
So true, but you might be able get a loaner and drive it 100 miles before picking up the car <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
