well the phuz instructions were like "remove these bolts and slide it out the top"
oh no. i had to push so hard on the radiator and AC condenser to get it out. the end tanks of the IC are sandwiched underneath the mounting points for the radiator and you cannot just slide it out. you have to push on the radiator towards the engine so the IC endtank in/outlets can clear.
if i would have removed the AC condenser i def would have just slid right out, but there was no way i wanted that mess. i have NO idea how IPD gets the IC out through the bottom. the only way to do that is to remove the radiator. the radiator mounts to the chassis to support all three coils. you have to remove those bolts to even think of having enough room to wiggle the IC out and once you remove those bolts they all just fall independently. so you have to pull up on one, push aside another, all while yanking at the IC.
def way harder than i thought it would be, and i work on cars a lot.
picture the mounting for the radiator to be a C on either side. reversed on the one side of course. now the circular inlet of the IC is going through that C. and you cant move the radiator side to side. the only way is in and out. yeah, PITA lol.
