Hello, I am in the process of assembling an engine for my S40 based on a 2.5l B52544T2 RNC turbo block and crank, rods. It is going to be a NA build, and I want to keep my compression ratio up around 10.3 - 10.5:1 (stock NA) rather than the turbo 9.5:1.
Can I use my stock '04 B5244S pistons with the 2.5l block,crank, and rods to do this?
Does anyone have the critical piston dimensions for the 2.5 and 2.4l 5cyl. engines
( pin center to crown height, dish volume, etc.) that I need to complete my build?
I'm not looking for forged pistons, just a decent set of OEM or aftermarket D grade slugs
to wrap this up. Thanks!
