Starting a build thread for my 2004 Passion Red s60R.
Some standard maintenance notes:
I do my oil changes every 5k miles with full synthetic 5w30
I replace my oil filter crush washers every-time, oil filter, and I like to do the fuel filter as well.
Current Modifications[Stage 2]:
Air vent boost gauge pod with Autometer Boost Gauge
Snabb turbo intake pipe
Phuzzy downpipe with cat
MBS catback exhaust
Magnaflow resonator and muffler
FM Intercooler
Silicone intercooler hose
IPD Ignition coils
Synapse DV 1.25''
OEM spark plug replacement
Volvo Air Filter (S60 S60R V70R) - K&N 8671488 ***Use the stock one, don't go K&N.
Snabb Upper charge pipe with Synapse weld on bung
Snabb intake pipe section with bung [replacing the old Snabb one,new parts can't hurt]
Snabb intake to DV hose
Snabb turbo block off plate
Planned [With parts]
Entire Vacuum system/line replacement with 4mm and 5mm silicone
Front and rear Akebono brakes from FCP
FCP Kit Engine mount replacement
Planned [ no parts purchased yet]
VIVA Maf upgrade for the tune http://www.vivaperformance.com/maf-upgrade-kit-volvo-5-cylinder-turbo-engines/
AEM Water/Methanol Injection Kit http://www.vivaperformance.com/water-methanol-injection-kit/
High flow fuel injectors
Wheel bearing replacement [x4 , general maintenance]
KW V2 S60R AWD Coilovers http://www.vivaperformance.com/kw-coilover-kit-s60-v70-fwd-awd-s80-fwd/
Hilton 2.5 Tune (unless I find a better option)
Suspension replacement [4C]
Front and rear seat replacements
=====New Stuff 3-26-17===
This is a pretty good guide if anyone needs a quick start
Got my VIDA/DICE unit set up 2014D. So I will be doing the following:
Sum Calibration/Headlight Calibration http://forums.swedespeed.com/showthread.php?156538-SUM-Calibration-with-VIDA-DiCE
MBS catback exhaust
FM Intercooler
IPD Ignition coils
Synapse DV 1.25''
