1 - 11 of 11 Posts
Hey Guys,
My R Auto's shifter does not stay in auto anymore. It will slide from the auto setting into the manual setting with no resistance what so ever. I have been investigating and found that there is a yellow tab that is probally broken in there but I cant seem to get past getting the boot and the shift knob off to get in there. Can someone shine some light on this?
Mine was broken as well a couple months back. Some Indy shops have rebuild kits for these, which they go out a lot. I would suggest you go and have them check it out. Sometimes the rebuild kit will cost like $100.
Sent from my 831C using Tapatalk
It's a pain to deal with... Take the shift plate off, then there's 4 plastic pins that go into notches on top of the shifter... Takes a lot of force to make them go.
The shift plate is what the boot is attached too with the gear indications on it correct? Thats where Im stuck at. How do I get the shift plate off?
You pry up on it... Remove the pen holder and pry up.
Still struggling here. I was able to look under the boot at the base of the knob and there is no pin. I did see a sort of clip style mechanism but its located under the base of the knob and seems impossible to get to. Am I goin about this wrong?
No. That's what I mean. They're on there pretty tight. Takes a lot of force. There are slots for a screwdriver IIRC.
1 - 11 of 11 Posts
