21 - 40 of 94 Posts
2005 S60 T5 M66 with 4c
Discussion Starter · #21 · (Edited)
Lots done to the car since last posting. The winter was really harsh and the car took a beating.
- Front lip got destroyed/lost driving to work in a blizzard.
- 12" crack on the windshield after road debris.
- Bluepower BLP-890 really took another dive so was removed.
- Coming up on 100k miles.
- Timing Belt/Water Pump service soon
The good news?
- IPD Sway bars, linkages, bushings, inserts to replace (already purchased)
- Ordering Lip and new Windshield next week
- Nexus 7 Installed as Head Unit
- HID Retrofit with TRS D2S mini projectors (either the 05+ Non-HID lights or a set of R lights I picked up on here) - Seems like my 05 lights can be opened up. Will try it when I have time.
Vehicle Car Electronics Multimedia Center console
More to come.
^Nice!
Tell me more about a tablet for a radio?
Sent from my SGH-T999L using Tapatalk
Damn only 79 of my car, I also have 4c :/
Discussion Starter · #25 ·
The Nexus 7 works great for radio. So much more functionality than the traditional DD setups and the interface is so intuitive as it is the latest revision of Android. When I eventually call up Verizon and turn on my hotspotting feature, data connection will not be an issue.
More on the Nexus 7 Installation here: Post #63
We both have rare birds. Can't wait till my downpipe/cat/exhaust start rusting away so I can replace them with EST's setup with a tune to see what the T5 can really do.
Do you still have the bluepower? I pm'ed you.
My car is 05 6Speed T5 Black sapphire metallic with Gobi interior. No 4C.
Curious to know how u plan on doing the hid projector retrofit? I mean 05+ s60 headlights are sonic welded the only way to open up the lens is to cut through it and glue it back together. If you have any other way of doing this i would definitely be interested to know as i too want to do a retrofit.
A projector retrofit can be done on the 05+ S60 if you use the aftermarket TYC lights http://www.ebay.com/itm/190961149458?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I was about to do a morimoto mini d2s projector retrofit but my car got totaled.
Discussion Starter · #29 ·
Got to spend some time with the T5 over the weekend.
Installed:
IPD top front strut bar poly inserts
IPD top engine mount poly bushing
IPD rear sway bar with mounts
Meyle HD rear sway bar endlinks.
Still to install:
IPD front sway bar with mounts
IPD subframe poly busing inserts
new steering stops
new subframe bolts, plastic washers
2005 morimoto d2s mini retrofitted bi-xenon R lights. (finally found the correct harnesses)
Viva CBV
still to do before end of the summer:
new Volvo windshield (thank you insurance)
new front sport kit lip (thank you insurance)
new front air guides (thank you insurance)
new front underbody tray (thank you insurance)
painting front lip, front bumper, and maybe rear bumper (thank you insurance)
"Needed" in the not too distant future:
new downpipe w/ cat (EST)
new exhaust (EST Touring)
IPD drop in intercooler
Custom Tune
I'll get some more pictures up when things are finished for the summer.
Discussion Starter · #30 · (Edited)
Finished retrofitting one side:
Headlamp Automotive lighting Light Vehicle Auto part
Morimoto Mini D2S 3.0 X-Lens "Square" Projectors with Gatling Gun 2.0 Square Shroud.
2007 R bi-xenon headlamps with reflector, bulb holder, high-beam cam wheel, and some material removed. Painted the housing guts matte black.
Custom wiring harnesses based off of the 2005+ R headlamp harnesses. Added a wire for DRL and a relay harness to power the ballasts.
I know what all the pins do from the headlight harness to the R projectors so if anyone needs that information, check back here or in the other projector retrofit threads.
I will install both headlights and the wiring harnesses in the coming month when I get time to install the front sway bar and a few other goodies.
Stay tuned.
in love with that head unit! where did you get the shell at?
Discussion Starter · #32 ·
the plastic piece surrounding the nexus 7
Discussion Starter · #34 ·
Reference the linked thread. I have a list of parts that I purchased.
Got the Scosche kit from amazon and had to machine off the entire inner bezel to have the Nexus sit flush. The opening is not sized exactly right (needs to be a little bit wider than the standard DD cutout), but was close enough so I did not enlarge the opening at all. You really will need a milling machine for this as it will almost be impossible to do it consistently with a dremel.
Discussion Starter · #35 · (Edited)
So a 3 year later update. Not really on here much anymore because I have no time.
Car now has 122k miles.
Finally got a free day to detail the car. Clay and Sealant.
IPD F&R Track Sways
IPD Sway endlinks
New Windshield
TRS Bi-Xenon Retrofitted R headlights still going strong
Back to OEM radio with Bluetooth IMiv
Left vent-pod with ipd boost gauge
Custom trunk LED lighting
IPD Downpipe
IPD Oval Exhaust
Timing Belt+Water Pump replaced
Front wheel bearings replaced
Rear shock mounts replaced
Finished a set of Continental DW and Blizzak LM-25's
Now on a new set of Continental DW's and Blizzak WS80's
Upcoming things for the future in no particular order:
repaint and remount sideskirts
reinforcing front lip and making a custom splitter
seal up rear bumper with a custom diffuser
wrap side mirrors
wrap interior components that are peeling
open headlights and remount projector bezels and relevel projectors
boost gauge dimmable gauge lighting
Hilton or Stevo stage 2 tune
Re-tint the rear window
Custom wiring for phones and such
New Steering rack needed because of leak
New ETM needed because of intermittent P2111 code and resulting limp mode
KW V2 coilovers when the 4C goes out
Clutch and flywheel possibly next year
While the trans is dropped add an LSD in there (if I can get one)
Repaint front and rear bumpers (NYC/Brooklyn Parking has taken its toll)
R Brembo Caliper upgrade when the current brake rotors+pads need replacing.
New wheels, just not sure which.
Discussion Starter · #36 · (Edited)
Still ticking away those miles, although much slower these days than years past. Currently at 136k miles. It's a great 20 footer. Needs some work close up though.
All interior plastics wrapped with Carbon Fiber Vinyl
Headlights releveled and resealed
Rear windows and sunroof retinted
Boost gauge illuminated
Custom wired phone chargers in radio pocket
Auto-Vox X1 rear view mirror LCD back-up camera with front/rear video recorders
Yellow Fogs
LED DRLs
Super bright Reverse LEDs
Custom trunk LED bar
Custom trunk cargo netting
Bluetooth OBD2 to Dashcommand on vent mounted Note 8
To Do:
R caliper upgrade in the works
Snabb/IPD Intercooler and piping upgrade
Stage 2 tune from contrast
Discussion Starter · #37 · (Edited)
Got a chance to wash and clay and seal the car a little while back. It's still looking good for a 13 year old car. Needs some paint work on the front and rear bumpers from NYC drivers that SUCK at parking, but that's expected.
Land vehicle Vehicle Car Bumper Automotive design
Bi-Xenon Projector Retrofit up close. Parts from TRS
Land vehicle Vehicle Car Headlamp Automotive lighting
Car's getting a pretty nice shoe present.
Auto part Brake
R Brembo Caliper set purchased from a part-out on here.
Also purchased new Brembo rotors, SS brake lines (FCPEuro) and a set of rear dust shields also from a part-out on here.
Also since the original Orpheus wheels won't fit anymore, some new shoes for her to sit on too.
Alloy wheel Rim Tire Wheel Spoke
Orpheus wheels offset wasn't enough. So instead of getting 12mm spacers, new set of wheels. FC04 in 17x8 +35 in Titanium. Thanks EST!
Pair that with a standalone TPMS system to bring this car into the 21st century.
Gonna be a fun installation!
So anyone looking for some Orpheus wheels and/or a 305mm rotor/caliper upgrade, look out in the marketplace.
I know this to be true about NYC drivers, this is where my car came from. Original buyer was from around White Plains, bought at Red Bank Volvo in NJ, and she drove into the city for work. Door dings and paints chips a plenty. Actually surprised it's not worse.
BTW, yours is looking great!
Love the car, so much that I am a proud father of your childs sibling...
Might have to ping you in the future regarding issues you might have experienced so far.
Just cleaned my throttle body due to it getting stuck and throwing the error code.
Cheers!
-Danny
Discussion Starter · #40 · (Edited)
21 - 40 of 94 Posts
