They are not high stressed bolts, reusing them is fine unless you see corrosion or damage.
^ +1 LloydDobler has provided you with proper direction. One trick that makes the install a bit easier, notice that the bottom bolt locations on the manifold are slotted. Start the bolts into the head first for the bottom, which also will hold the gasket in place while you set the manifold onto the bolts. Then install the tops and torque from the inside out.
