Does anyone else have kind of soft feeling brakes in their S60?<p>I have an '01 S60 T5 and the brakes have always felt somewhat soft, with excessive pedal travel. I bought the car used.<p>I have switched fluid and powerbled the system, but it didn't help. Nothing is leaking fluid, so I am wondering if something is possibly wrong with the booster. Has anyone else had a similar issue?
Re: Brakes Soft? (Tim G)
Nope, thats just the way they are. Even changing to stainless brake lines does not get rid of the soft feel.
Re: Brakes Soft? (ss60)
Ouch. That stinks.<p>Does an upgrade to the larger R calipers and rotors (on the front at least) help?
Recently I drove a 2006 S60 2.5T and I remember the brakes were so sensitive, if you put the weight of your foot on the pedal it was enough to bring the car to a screeching halt. (Slight exaggeration)<p>I have also driven a 2003 S60 T5 (144k miles) and the brakes felt much softer. <p>So maybe your rotors/pads need to be looked at?
I put some work into my T5, just basic replacement of fluids, rotors and pads. I had to bleed the brakes quite a bit, but achieved a really nice firm feel. It really took a long time to get the peddle high and tight. I think it just takes a little work. If you're not doing the work yourself, it's a little bit harder as most mechanics will just do the job until everything is 'within spec.' I added ss lines about a week later, so I had to repeat a little of the process. The ss lines even firmed it up more! <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>
