I am considering upgrading my brakes. I need to replace my brake pads soon and I was going to go with Hawks all around but then I started thinking of maybe replacing the front rotors with a pair of slotted ones. I was wondering how hard it was to get a little bit of a larger rotor while still keeping the stock caliper.
Thanks
Re: Brake upgrades (Heimpel)
I haven't researched larger rotors but my guess is that you'd have to have a new caliper mounting bracket in order to use a larger rotor. I don't kmow if such a thing is available.
Hawks work good. When I need to do brakes I'm going to use EBC greens. I have used them on other cars and they are easy on rotors, low dust, low rotor wear and work as good as the street hawks. I know they are available for an 04 S60 but seems like they are not for earlier years.
Quote, originally posted by Heimpel »
I am considering upgrading my brakes. I need to replace my brake pads soon and I was going to go with Hawks all around but then I started thinking of maybe replacing the front rotors with a pair of slotted ones. I was wondering how hard it was to get a little bit of a larger rotor while still keeping the stock caliper. Thanks
Check out EuroSport, as they seem to have a fairly large selection of rotor upgrades (slotted, cross drilled, cadmium plated, etc.). You might be able to find a decent set that will fit your stock calipers...
my friend got some new upgraded brakes for his M3 and i was wondering if i could fit his stock M3 brakes onto my S60...idk much about brakes or bolt patterns...could anyone please help me...if it helps or matters it is from a 2002 M3
