1 - 9 of 9 Posts
Yesterday I was driving on the expressay and upon applying the brakes I noticed a shuddering/thumping that felt like it originated in the rear of the car..I felt it right through to the steering wheel and the whole car seemed to shake whenever I applied the brakes at 50+ mph...It doesnt happen down at lower city street speeds and only happens once in a while. Could my rotors need replacing or resurfacing? Anyone had this problem?<BR><BR>
<i>Modified by cicatrizdare at 4:57 PM 6-3-2006</i>
im not sure myself how ABS tech works, i'm sure someone here will but I've had it before where it kicks in on sudden braking even its not slamming onto them<br>i get it on wet roads too<br>and sometimes i get it when I think it shouldnt but leave it to the cars brain to decide
Re: Brake Thumping/Shuddering (cicatrizdare)
This sounds like a rotor issue, maybe warped due to over/under torque, etc. I would have it checked asap.<p>Tom.
Re: Brake Thumping/Shuddering (tmtalpey)
When I take it to service should I tell them that I think there's a problem with the rotors, along with the shaking problem at cruising speeds?
Just demonstrate it to them, don't tell them what to do.<p>Tom.
It doesnt seem to be a continuous thing though, itll happen on occasion when im driving for more than half an hour at +40-50 mph...and i'm not sure if theyll be able to reproduce the problem..<p>If they can't reproduce the problem but I insist that its there, can they still be made to change/adjust/do whatever they can to the rotors or anything that might solve it?
If it isn't continuous, then try to figure out what exactly triggers it. I am guessing heat, which means you should try 5 or 10 HARD stops from at least 40mph, until you smell some brakes. Then see if it happens.<p>Tom.
1 - 9 of 9 Posts
