It appears to be a separate part from the booster. According to the diagram in the link, it's part number 10. It's kind of pricey, but not as expensive as a whole booster. Definitely investigate the wiring going to the sensor to make sure something dumb isn't going on. Otherwise, if the booster isn't causing any trouble and isn't making a hissing sound when fully depressed. it's probably fine.
https://www.tascaparts.com/auto-par...8-gas-engine/brakes-cat/hydraulic-system-scat
Volvo Part #30769206
Parking brake service
Does anybody know what could be wrong?
This message apears almost every day in the summer when it is hot. In winter maybe once a month. When I restart a car, it goes away.
But even with message on, brakes works normally.
Someone told me that sensor in brake booster is faulty, but the whole brake boster should be replaced - 700€ :confused:
https://www.dtcdecode.com/Volvo/BCM-C004701
https://www.dtcdecode.com/Volvo/BCM-C004762
My expert with a good code reader said it was the module located in the trunk.
See my post just before yours.
He has one coming from Erie Volvo, should be here today.
I will let you know.
Sixvolvos13
