Hey help me please, I want to know what to do. I would really appreciate a recomendation on brakes. I would like to add something also. I understand that Sliding calipers, what volvo uses, is an efficiant cheap way to have disc brakes, but not the best performing. One person told me they offer less clamping power, but that also means less heat and stress on the rotors. We all know how bad the stock rotors were at warping, so upgraded rotors make sense. Besides the extreme expense, I dont want to use one of the big brake kits because it requires 17" wheels, something I dont want to do in the winter. Is there any way to convert the stock system to something using fixed calipers(is that what they are called). I would want something with two or 4 pistons so I could have the increased biting abilities they offer. I have the slotted rotors, and may go to slotted and drilled next, as they offer a reduction in heat, but also a reduction in surface area, I think extra gripping would be needed. Anyway, if all you can add is some good pads, let me know what you all have used and like. If anything I say is in error, let me know, I like to learn, but often get wrong info in the process from others who only think they know. Thanks.
-Matt
-Matt
