Hey guys<p><br>I need some help. I am ordering some Green stuff pads for my car and they have asked which dimensions my pads are on the rear brakes. <p>I have these two options<p>A: <A HREF="http://www.ebcbrakesdirect.com/car/image.asp?image=DP21354" TARGET="_blank">http://www.ebcbrakesdirect.com...21354</A><br>B: <A HREF="http://www.ebcbrakesdirect.com/car/image.asp?image=DP21749" TARGET="_blank">http://www.ebcbrakesdirect.com...21749</A><p>What am I running? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/confused.gif" BORDER="0"> <p>2004.5 T5 FWD <p>THanks in advance!
Do you have 300mm or 320 mm brakeS?<p>Use this pic for reference, the smaller one is the 300mm and the other 320mm (wich is, btw for sale- Full BBK, direct bolt on).<p><IMG SRC="http://img144.imageshack.us/img144/9383/p1000405.jpg" BORDER="0"><p>EDIT: Ups... just saw... rear brakes... I always thought ours cars only had 1 size rear brakes :S
Re: Brake pads (TheDane)
You should have the 280mm rear rotors and appropriate calipers unless something weird is going on or you upgraded already. <p>Wish I could help more, but they're kinda hard to measure once installed. You need ones that are the same size as Hawk HPS HB478F.605 if it helps.
I'll go with the smaller ones and then we will see what happens. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
