Okay, the bulb indicator went off on our new 245. I replaced the bulb, which was visibly blown with a new bulb. I checked the brake lights and they worked properly. Then I got in to drive somewhere and the indicator light was on again. I went back and played wiht the connection as I had someone step on the brake. It would light up if I pushed on it.<P>Then under driving, it would not work most of the time, and work sometimes under braking and (here's the odd part) when I hit the turnsignal, though sometimes just momentarily. I am judging all of this on monitoring the indicator light during my holiday driving.<P>I figured it's a loose connection or a connector in need of a little sanding, but the turnsignal part has me puzzled. Any ideas?<P>Also, the high beams were not working on the car as well. I'd hit them and they would go off. I replaced one bulb and still no high beams, then I replaced the others and hit the high beams and they worked. I figure this might be some sort of circuit setup by Volvo, but again, just thought it was odd. The high beams work fine now.
