1 - 11 of 11 Posts
Just got the yellow warning triangle when I hit the brakes that there is a brake light failure. Did a quick search but couldn't find a bulb #. Anyone replaced their brake lights recently and remember the bulb #? I could go pull the stupid thing out but I'm at work and wanted to run out at lunch and get a pack to replace it. TIA.
or 5006 either should work. worse case take the bulb out and bring it to an autozone and compare
Thanks. But isn't that the position bulb number and not the brake light?
Does 7506 sound right??
When I had a brake like go out I used a 5007, but maybe we are talking about different bulbs.
Report back after you replace
The brake light is definitely the 7506. Unfortunately, when I closed the trunk it killed one of the position bulbs that is 5007 so I had to go back in and buy those as well. :rolleyes:
1 - 11 of 11 Posts
