1 - 9 of 9 Posts
I have a xc90 2004 . For some reason my right front caliper gets stuck and won't let the wheel spin, I replaced the caliper but have the same problem...what can I do? Thanks
first thing to test... when the wheel locks up, jack the car up, loosen the bleed valve (this will probably require a rebleed of the system) and if the caliper lets the wheel free, then you know that the problem is not with the caliper. From there, i would look at the ABS module.. .
not sure. If it were your master cylinder or booster pump, you would have pressure on all 4 corners. The ABS is basically a relief valve so it make sense that as you drive around, apply pressure to the brakes, the pressure isn't backed down on that one line.
Yea I also think the master cylinder and booster is not the problem, but how can I know it's the module or how can I fix it?
Sometimes the brake hose swells and develops into a 1-way valve: i.e., it allows fluid to flow forward but not backward.
1 - 9 of 9 Posts
