1 - 6 of 6 Posts
Greetings,
Just recently I started having this Brake failure warning light come on under hard braking or hard cornering, it would come on, and go off for a second.
Any idea why this is happening, I do have 215/60 tires instead 215/55 can that play a difference? I have checked the pads, they are fine, will check the brake fluid level tonight, but I think it was fine also.
probably a abs sensor going bad or the sensor grooves have some debris in them. if you had a VIDA tool it could tell you exactly which wheel
Fluid level is OK, also pads are fine, wouldn't the ABS light be on if one of the sensors malfunctions?
1 - 6 of 6 Posts
