01 s60 2.4 auto 170k miles. So I replaced calipers, pads, rotors all the way around recently after the calipers started ceasing. Good times. Suddenly I'm getting a service message stating: 'brake failure, service urgent' and the red 'brake' indicator in the bottom right of the cluster comes on as well. It happened once when I hit the brakes pretty hard to avoid bottoming out on an unmarked speed hump. It has happened twice again, both times on the hard bank right of an interstate exit ramp. The message is only present for about 5-6 seconds so no ability to grab a pic.
No codes stored (non-VIDA OBDII). I had a mechanic (not a Volvo specialist. I know, I know) look at the calipers and they said everything looks fine, that the calipers are operating properly. This morning when I backed out of a parking spot I could feel that a brake was slightly engaged and I heard a light squeal. I also had new e-brake shoes and cable installed. Could a malfunctioning e-brake cause the message? Any thoughts on what would be causing this? Thanks in advance for your assistance. GH
