i recently purchased a 89' 245. it is in pretty good shape, but the brakes were in need of a replacement. i bought pads, clips and shims from a local volvo dealer and proceeded to do the installation at a friend's house. the replacement was quite easy. he has an electric lift in his garage so it made the whole job go much easier and there were not as many headaches as usual. now here is my problem.<BR>after they were installed the "Brake Failure" light came on and would not go off. we wound up draining all of the brake fluid from the lines and putting new fluid in. after bleeding all of the lines the light was still on. we were able to get it to go off by "reseting" the rear passanger side hydraulic thing.<BR>it is now about 3 weeks later and the light came on again. it stops the same way as before and there are no new brake noises(but i do have a mysterious thud that happens when i turn the wheel sometimes, but that is another post). do any of you know what may be causing this? is there any fix that i can try? do you know of any Volvo mechanics in the Evanston, IL area?<P>Thanks in advance.<P>Matt
