1 - 17 of 17 Posts
Recently I have been seeing a red "brake" signal lighting up in the instrument cluster, accompanied by the warning "brake fluid low" when I am accelerating into a hard turn. <p>The light goes off after a few seconds, as does the warning message in the message box. <p>Is this something I should be concerned with??? It was not doing it before. It might just need some fluid...although I believe our brakes are "sealed" which would imply a leak somewhere.<p>Based upon your responses I may be taking her back to the dealership. I swear I have such a love hate relationship with this car...I want to keep it "until the wheels fall off" but at this rate that may be sooner than I anticipated.
Re: "brake" during hard turns (esquiR)
Check the lines for fluid leakage. Or spend the 80 to get them pressure bled, and someone else can get all messy.
Well the 1st thing is (duh) open the resovoir and check the brake fluid level!<br>If low, top off, THEN figure out why.<br>If your brake pads are low, that alone could do this
Thanks for the input.<p>What kind of brake fluid does our car require? Dot 3,4 or Dot 5? <p>Will check the fluid this afternoon. I don't think the brake pads are low...don't recall when they were last changed specifically but it has not been that long. Additionally, I have not heard any squeal or grinding noises which usually accompany worn brakes.
Re: "brake" during hard turns (JRL)
I had this happen to me before going around the same hard left turn on my way to the g/f's house. I just did what Jim said, and no message since.
Re: "brake" during hard turns (MancUnited1)
IIRC the R shares its brake fluid with the clutch. It can be clutch related. Can it be the slave cylinder on its way out? Any seals around there that can leak?<p>When you top it off, be sure to use DOT4<B>+</B> fluid, emphasis on the "+" (higher temp rating than regular "4" alone).
Re: "brake" during hard turns (S60R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>S60R1</b> »</i></TD></TR><TR><TD CLASS="quote"> Can it be the slave cylinder on its way out? Any seals around there that can leak?<br></TD></TR></TABLE><p>Exactly! Check the bottom of the tranny for brake fluid, your slave might be leaking...if you have a manual.<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Well the 1st thing is (duh) open the resovoir and check the brake fluid level!<br>If low, top off, THEN figure out why.<br>If your brake pads are low, that alone could do this</TD></TR></TABLE><br>Need we say more!!!
Moderator
Your brake pads are low! I had the same issue on a previous Volvo <br>Most likely inner rear pads (the ones hard to see)<br>Do not fill your reservoir - check your brakes.<p>Could also be a failing slave cylinder...aka clutch job <BR><BR>
<i>Modified by tomedkaz at 4:46 PM 7-8-2009</i>
Most brake fluid resivor's are designed to never have to be topped off. If the fluid's low, assuming no leaks then you're due for brakes.<p>If you have a stick shift, given the great history of our slave cylinders i'd take a peek under the car too and see if the bottom of the bellhousing shows signs of leakage.<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>MancUnited1</b> »</i></TD></TR><TR><TD CLASS="quote">I had this happen to me before going around the same hard left turn on my way to the g/f's house. I just did what Jim said, and no message since.</TD></TR></TABLE><p>same here
Re: "brake" during hard turns (FEO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote">same here</TD></TR></TABLE><p>...you went to MancUnited1's girlfriends house?? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"><p>Back OT: +1 to MancUnited1 and FEO.<p>-Steve
Re: "brake" during hard turns (tomedkaz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>tomedkaz</b> »</i></TD></TR><TR><TD CLASS="quote">Your brake pads are low! I had the same issue on a previous Volvo <br>Most likely inner rear pads (the ones hard to see)<br>Do not fill your reservoir - check your brakes.<p>Could also be a failing slave cylinder...aka clutch job <p><br><i>Modified by tomedkaz at 4:46 PM 7-8-2009</i></TD></TR></TABLE><p>+1<p>if you top up now the reservoir will overflow when you change your pads (assuming you don't have any leaks)
Re: (esquiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>esquiR</b> »</i></TD></TR><TR><TD CLASS="quote"><br>What kind of brake fluid does our car require? Dot 3,4 or Dot 5? <br></TD></TR></TABLE><p>Do NOT use DOT3 or DOT5. Actually, don't use DOT4, you should really find DOT4+ like ATE Super Blue or Motul 600, or just get Volvo OEM fluid, it can be ordered for a good price too.
Discussion Starter · #15 ·
will this suffice as a replacement brake fluid?<p><A HREF="http://www.cbxmanmotorcycles.com/Castrol-12502-Gt-Lma-Dot-3-4-Brake-Fluid-12-Oz.aspx" TARGET="_blank">http://www.cbxmanmotorcycles.c....aspx</A>
Re: (esquiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>esquiR</b> »</i></TD></TR><TR><TD CLASS="quote">will this suffice as a replacement brake fluid?<p><A HREF="http://www.cbxmanmotorcycles.com/Castrol-12502-Gt-Lma-Dot-3-4-Brake-Fluid-12-Oz.aspx" TARGET="_blank">http://www.cbxmanmotorcycles.c....aspx</A></TD></TR></TABLE><p>I would say NO unless you can find the exact wet/dry boiling point so you can verify that it is equal or higher than OEM fluid. Considering it's advertised as DOT3/4 I really doubt it. Usually only stuff advertised as DOT4+ will be better than OEM.<p>Just get some ATE Super Blue or Motul 600 from zeckhausen or apexspeed.
Discussion Starter · #17 ·
Re: (Warpedcow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Warpedcow</b> »</i></TD></TR><TR><TD CLASS="quote"><p>I would say NO unless you can find the exact wet/dry boiling point so you can verify that it is equal or higher than OEM fluid. Considering it's advertised as DOT3/4 I really doubt it. Usually only stuff advertised as DOT4+ will be better than OEM.<p>Just get some ATE Super Blue or Motul 600 from zeckhausen or apexspeed.</TD></TR></TABLE><p>Thanks Warped cow...I ended up going to the dealership and getting OEM fluid. Added some and then took a few corners at speed to see if I could trigger the problem.<p>Looks like problem solved, at least for now.
1 - 17 of 17 Posts
