1 - 19 of 19 Posts
I have a 2005 s40 T5 AWD and a friend of mine has the 2004 model with front wheel drive ; as the cars were sitting near one another we've noticed that the brake discs were way bigger on my car ; is it because my car is basicaly heavier due to the all wheel drive or did they improve the brakes in the meantime ? and another thing ,does any of you know what are the dimensions of the brake discs , front and rear on my model ?
Re: Brake dimensions (passat)
In general the brakes are bigger on the newer version. <br>Spec says 300mm calliper for 16" wheels and 320mm for 17" wheels.<p>Is this what you are looking for?<br><A HREF="http://www.volvoclub.org.uk/tech/S40MY2005-Brakes.pdf" TARGET="_blank">http://www.volvoclub.org.uk/te...s.pdf</A>
The AWD with a stick gets the larger front brakes. Non-AWD and autoboxes get the smaller ones. No clue why. It isn't the weight. Not that I'm complaining.<p>Tom.
i can't seem to find aftermarket drilled brake rotors for my car ; the stock ones are gone in just 25,000 km and not under heavy solicitation ....not lot of "mileage" in my opinion
Re: (passat)
I had the same problem trying to figure it out, the dealer I went to in Brooklyn, couldn't figure it out either. Tom and Boston Volvo gave me the correct answers.<p>-Nelson
Re: Brake dimensions (volvoNB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>volvoNB</b> »</i></TD></TR><TR><TD CLASS="quote">In general the brakes are bigger on the newer version. <br>Spec says 300mm calliper for 16" wheels and 320mm for 17" wheels.<br></TD></TR></TABLE><p>Whoa! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> Does this mean that if I have 17 Sagittas on my AWD V50 that 16" steelies with winter tires won't fit <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: (passat)
I had my rear wheel off yesterday and noticed "FoMoCo" on the rotor. So you may want to cross shop with other Ford owned cars. The few cars I know of with the 5x108 bolt pattern are Thunderbird, Taurus, and the Windstar.
Re: (volvoNB)
off topic but anyway: how depressing is it to see FoMoCo branded all over the car? it makes my heart sink every time I see it <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0">
Re: Brake dimensions (Dede)
Can anyone offer any insight on fitting 16" wheels on a car that originally came with 17 inchers? Is it possible?
Yes it is possible. I did it with my FWD T5 when I put on a set of winter tires and had no problems with rub or anything else. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Dede</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Whoa! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0"> Does this mean that if I have 17 Sagittas on my AWD V50 that 16" steelies with winter tires won't fit <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> </TD></TR></TABLE><p>No. Volvo's point to make here is that these are the <I>smallest</I> diameter wheels that you could install on the specified car.<p>John Sharisky<p>
Re: Brake dimensions (Parts @ Boston Volvo)
I disagree. I have the Sport Suspension pckg which came with 17" sag's standard on a 6spd T5 FWD S40 so I would "assume" that it has the larger rotors and the 16" rims that I put on with Dunlop M3 Sport Tires for driving in the snow worked flawlessly.<p>Unless the larger rotor's are only on the AWD version in which case the above info can be disregarded. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0"> <p>*<I>Edit:</I> just saw that tom pointed out that the larger rotors are only on the MT AWD version....which would make my above comments useless. <p>On a side note, however, that does mean I can run the larger brakes standard on my non AWD car just fine behind the 18's <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Brake dimensions (Tarheelvolvo)
my 2.0D 6speed manual has bigger brake disks <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"><br> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> (it came with 17" sagittas)
I've always read in all reviews of the S40/V50, (T5 FWD,AWD,automatic, manual) that they have 11.8 in. front discs. Same with the Mazda 3. I have a hard time believing that the Mazda 3 comes with these but on the S40 only the AWD manual....
Re: Brake dimensions (s40turbo585)
i recall there was a long discussion on apparent brake disc sizes before..<br>but if IIRC, the only difference in brake discs were between T5 and 2.4i variants and not as between AWD and non AWD.<br>
Re: Brake dimensions (Mistral)
This is an interesting discussion. I have a Worldpac account, so I pulled up a 2005 V50 2.4i, and checked the rotors. Here's what Worldpac calls for....<p>15" Wheels - 278mm rotors<p>16" Wheels - 300mm rotors<p>17" Wheels - 320mm rotors<p>Worldpac lists the exact same parts for a T5 AWD as well. Seems to be a wheel size thing, and not a vehicle thing. It would seem that if you ordered a 2.4i with 17" wheels(sport package), you get the big brakes, same as an AWD T5. By this, a 2.4i with sport package would have larger brakes than an AWD without sport package. Odd.<p>All I know for sure, is my AWD has 320mm brakes, and they are 70% worn after 16000 km. I'm going to slaughter them before 20k, so I can warranty the damn things.<p> Al
Discussion Starter · #18 ·
mine gave up on me at about 23 000 km <br>no warranty what so ever , so i'm searching for aftermarket drilled ones to change them ; unfortunately , haven't found any <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: (passat)
Warranty is 1 year, or 20000km, which is why you got nothing at 23000km. I checked mine at 15000, just to see how they are, and low and behold, they're nearly done. I plan on killing them completely before 20000.<p> Al
1 - 19 of 19 Posts
