1 - 6 of 6 Posts
Hey guys,<br> Is there a concensus as to what order to bleed the brake calipers? Any tricks i should be aware of?<p>thanks!<p>
Re: Brake Bleeding Sequence (metalworker)
I think the standard advice is to start with the wheel farthest from the master cylinder (right rear) and work your way closer in (RR, LR, RF, LF). Hopefully someone with more experience will correct me if I am mistaken.
Re: Brake Bleeding Sequence (VTT5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>VTT5</b> »</i></TD></TR><TR><TD CLASS="quote">I think the standard advice is to start with the wheel farthest from the master cylinder (right rear) and work your way closer in (RR, LR, RF, LF). Hopefully someone with more experience will correct me if I am mistaken.</TD></TR></TABLE><p>thats how i was told to do it when i did my saab. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>VTT5</b> »</i></TD></TR><TR><TD CLASS="quote">I think the standard advice is to start with the wheel farthest from the master cylinder (right rear) and work your way closer in <b>(RR, LR, RF, LF)</b>. Hopefully someone with more experience will correct me if I am mistaken.</TD></TR></TABLE><p>That is correct.
Re: Brake Bleeding Sequence (R Salesman)
FYI there are two bleeder screws per caliper, an inner and an outer. When I bled mine I went RR, LR, RF, LF. I also bled both inner and outer (can't remember which first), but the second screw only takes a second or two (you are only clearing out the old fluid in one half of the caliper).
Re: Brake Bleeding Sequence (JAGMAN)
The R has two separate systems. You can bleed either the front or rear first but start with the wheel farthest from the master cylinder. RR to LR or RF to LF. Also start with the inboard bleeder first then the out board bleeder.
1 - 6 of 6 Posts
