hey guys just wanted to ask you guys a question. I just purchased a turbo xs dual stage boost controller and I was woundering if you guys knew what would be a reasonable amount of extra boost, I was planing on going up to 12psi. let me know what you guys think, and the car is a 05 T5 awd.<p>Thanks guys
check out these threads: <br><A HREF="http://forums.swedespeed.com/zerothread?id=61547" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61547</A> - <A HREF="http://forums.swedespeed.com/zerothread?id=61594" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61594</A> - <A HREF="http://forums.swedespeed.com/zerothread?id=60758" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=60758</A>
Re: (V50_T5)
Problem with a boost controler IMO is the turbo can supply say upto 18 PSI of boost at 3000 RPM but all even the most agresive chips push the boost back to 9 or less PSI at 6000 RPM. Since this turbo is so so close to be over the edge driven, I would not fool around with anything that could drive the turbo at or above 9 PSI around 6000 RPM... Now if the turbo is changed out and some sort of additional fuel added...
