First off, I just want to state that I am not looking for some crazy horsepower goals. I don't want change out the internals of my motor, and I don't want to worry about cylinder separation or throwing a rod. Gone are the days and the desires for me to piggyback my ECU, or have a ton of extra gauges in my cockpit to monitor, with the exception of boost pressure. I don't want to always have to worry about EGT or AFR (with the exception of datalogging runs for proper tuning). After my deployment, my priorities shifted and all that went to the wayside. I just want things simpler.
That being said:
Is there a bolt on turbo out there that will widen the powerband and bring our cars to a safe and reliable 400-ish bhp without the worries? I've seen some archived threads on the subject, but it seems their goals were a little higher than mine. I guess the closest thing I've seen is "turbo for the masses?? [Archived]" where the OP modded his turbo with a K26 turbine wheel and a larger compressor from Majestic, but it was alive in 2006 and I was hoping there was more R'n'D done since then. I am assuming this was done with a custom DP/exhaust manifold... No mention of whether or not there is a safe/dependable tune for it, or how his engine held up over time.
