Hello!
Could someone recommend a fairly integrated-looking and -functioning Bluetooth solution for my 2002 S60 AWD which obviously does not have a Bluetooth-ready HU (if one exists)? I'm not sure exactly how aftermarket units work (if they can work thru the car's speakers) but I know I can't use the Volvo OEM one.
For lack of a better aftermarket solution, could I change the HU for one that's Bluetooth ready and use the OEM Bluetooth kit? I current have the HU-613.
Would the fact that I'm looking into an IMIV have any bearing or is it exclusively a matter of the HU being compatible?
Thanks!
Re: Bluetooth solution for S60? (landsmarra)
The easiest way is not to integrate. Just put the BT speaker under the center speaker grille and turn down the radio manually when you get a call.
