Hello<p>I need some help for a Bluetooth car kit installation. (Parrot CK-3000 evolution). <p>I bought already an ISO-Volvo adapter and figured out how to do the wiring, but my problem is that I don’t know how to route the wires from the trunk to the driver seat.<p>Anyone can help me?<br>
Re: Bluetooth car kit installation, need some help (ben_1.8i)
I believe you may find the answer if you look at GoSwedeRacer's "how-to" post down on <A HREF="http://forums.swedespeed.com/zerothread?id=47363&page=2" TARGET="_blank">this page</A> .... See point #3 <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"><p>
Re: Bluetooth car kit installation, need some help (Dede)
<br>"Route the cables along the left wall, behind the carpet, through the trunk (while the back seat is folded down). Pull off the small cushion on the rear driver's side seat. You can route the wires behind that then under the carpet along the door sills until it gets to under the drivers seat."<p>Yeah, I read that post but I'm still having questions, Do I have to remove the plastic part of the sills, if yes how can I do it? What do I have to do to remove the small cushion, just pull strongly?<p>I need to be sure, don't want to break anything<p>Thanks<p><A HREF="http://img100.imageshack.us/my.php?image=sillsbv0.jpg" TARGET="_blank"><IMG SRC="http://img100.imageshack.us/img100/710/sillsbv0.th.jpg" BORDER="0"></A>
The side cushion is just pulled off. I don't recall in what direction, but if you look you can see which way to pull.<p>The door sills are held in place by plastic pins. It is easily removed. Just pull up with your fingers. Don't be afraid to break anything as they are strong.<p>After you remove the sills, you can route the wires under the carpet. Once you reach the B pillar, you'll have the just shove it under the plastic to hide it, then continue on to the driver's door sill, which is just as easily removed.
Re: Bluetooth car kit installation, need some help (GoSwedeRacer)
Thanks GoSweeder, seems easy now.<p>As soon as the adaptor comes, I'll do the job and take some pictures.<p>
