Blown struts...what else to replace?
2126 Views 6 Replies 6 Participants Last post by  rushin_max
Just got some new tires + alignment and discovered both of my front struts are "blown" @ 65K mi ( fluid leaking from the top of the tubes)
So I know I need new struts....but what other suspension wear items I should replace while everything's apart? springs, spring seats, end-links, ball joints, control arms, etc.
Front strut/spring assembly:
http://www.trademotion.com/par...gid=0
Front susp. comp:
Trying to make a parts list.
Re: Blown struts...what else to replace? (rushin_max)
Upgrade the spring seats at least... get the XC90 or the iPD HD aftermarket seats.
Decent time to do the endlinks as well. Wehn I did my V70T5, I did the bearing plates as well, just so I knew when everything was replaced.
Everything will be apart, so if you have any urge to lower the car, do it then! You can get a set of Eibach springs for under $300 shipped.
Re: Blown struts...what else to replace? (GiRaff3)
After replacing the strut plates and strut mounts and getting an alignment, does the car need to get a SUM calibration? Or is the SUM calibration only needed if the car was lowered?
Quote, originally posted by rushin_max »
Front susp. comp:
considering the cost of these struts...
Are we capable of re-packing the 4C struts?
Has anyone ever tried repacking at a autoparts shop?
Modified by Jersey R at 3:43 PM 3-23-2009
Re: Blown struts...what else to replace? (Jersey R)
Quote, originally posted by Jersey R »
AS anyone ever tried repacking at a autoparts shop?
There was a thread a while back on this exact topic. The last I read in the thread is it hadn't been done before but one individual was pursuing it.
3
Re: Blown struts...what else to replace? (atacamaR)
Quote »
Was wondering the same thing...currently doing more research. I know they're made by Monroe, maybe one of their kits would work w/ 4C shocks?
Quote, originally posted by atacamaR »
I think this is the thread u'r referring to...
http://forums.swedespeed.com/zerothread?id=104554
so far my shopping list (per side):
Shock/spring assembly parts:
Strut(#1)_______________$500
Bracket(#2) ____________$1
TME Spring(#3 )____350/4=$90
bump stop(#4)__________$20
dust boot (#5) __________$10
washer back?(#6)________$4
IPD HD Spring seat (#7)___ $45
Febi bearing(from IPD) (#8) $90
insert (#9) _____________$7
washer (#10) ___________$5
nut(#11) _______________$2
cap (#12) ______________$1
Total:______________~$775 (per side)
Add in the...
IPD endlink______$60
Ball joint________$45
Tie rod(outer)____$80
Tie rod(inner)____$25
Control arm_____$85
Total______$295 (per side)
+ var. bushings/hardware
So with the steering components, total is slightly north of a 'G' per side.
Anything else I forgot? Would it be fair to say that the whole front end suspension/steering overhaul will cost ~ $2500 in parts alone?
I don't know if I should laugh, or cry
