1 - 11 of 11 Posts
So i removed my front winglets cause of the damage they had to them, plus i have a hard time getting into the driveway straight. So i got them off and they were being held on with wood type screws. The car was used and the dealer said they had fixed the winglets just before i purchased it. Well long story shot, there is this black rubbery stuff that is left on the bumper and i have tried heat, goo gone and finger nails and its kicking my butt. Any one had this same problem? what did you do?
Re: Black Stuff?? (thorne)
Is it like an adhesive, or a gum like substance? You might want to use some ice to harden it and chip it off. Kinda like gum in the carpet.
Good luck.
OFF TOPIC:
Do you want to see your winglets? I need a set.
I had the same problem, I used rubbing alcohol and WD40 to take it off, it just takes time. I was advised that WD40 is NOT a good idea, but I was getting the bumper resprayed, so that could have been why, I don't think it will destroy your paint.
I would sell them, but the wife rammed a curb and pretty much exploded them. They are really not worth it. The black stuff is rubbery, not really sticky, just really stuck on there.
Re: (thorne)
Patience and goo gone helped me. I used a razor to get the bulk of it off (carefully...) and then time, a rag and goo gone seemed to work.
Re: (thorne)
Quote, originally posted by thorne »
what do you fill in the holes with
Hole filler.
I have used WD40 to remove stuck on sh*t all the time, works great.
Re: (850arrrsaylikepirate)
Quote, originally posted by 850arrrsaylikepirate »
Hole filler.
Dare I say...that's what she said?
Re: (jdog)
you need to use something like naptha. I think 3m calls it "trim & adhesive remover" avail at good auto parts stores or body supply places. Worked like a charm for me; made easy work of it
1 - 11 of 11 Posts
