Re: Bigger brakes for 850 T5R (Puraplata)
Yep!! Volvo had a 302mm kit that came on some C70s and S70/V70 T5s. Stock 850s have 280mm.
I just installed my kit last weekend actually. No real improvement in braking, only in brake fade (less of it). They use the same calipers just different brackets and rotors. Install was easy! They fill out my 18s a lot better than the 280s.
Or there is the S60R/V70R Brembo kit that's a direct swap as well.
Or there is the 993 porsche/brembo kit which is also a direct swap.
Both the above kits are pretty pricey though.
I have a Wilwood Kit I sell for the 850/V/S/C70s for $1000 shipped .
Its a 330m brake kit . Uses the same rotors as the S60Rs
Right now is just finding out what wheels it fits with and without spacers.
Re: Bigger brakes for 850 T5R (Wagoneer)
rear only:
Quote, originally posted by Wagoneer »
front:
? no clue yet I am waiting on a set of pegs to see if those fit first .
I had a set of propus on mine but needed a 5mm spacer to make them work
