1 - 8 of 8 Posts
We have an unusual problem with my wife's XC 60. The automatically adjusting headlights keep adjusting excessively with big swings up-and-down while we are driving. This is incredibly annoying and distracting. Now, I may have inadvertently triggered this behavior when I did the front strut swap a couple of months ago. The headlight adjusters are bolted to the lower control arms. I had to simply unbolt those as part of that install. It is a fairly simple remove and replace with one bolt however, so I'm not sure what I could have messed up. Regardless, I did ask the dealer to recalibrate the headlights at our last visit which they indicated they did. However there was no change. To be clear this is a new behavior. Any insight as to what may be happening here and what the solution might be?
Is your warranty not in force on the xenons due to the strut swap? Seems like the dealer could trouleshoot.
Are the headlight assemblies securely attached to the car?
The retaining clips on the headlight assembly, particularly, the passenger side assembly, sometimes break during removal at services.
Well, I'm pretty sure I have discovered the issue or, in my case, ISSUES (plural). I need to actually test drive the car tonight to confirm. As suspected, I introduced what is likely the majority of this problem, BUT as qaz996 notes I ALSO ave a busted headlight! Here are the specifics:
Headlight Sensor: There are two sensors "level" sensors on the XC60 (Xenons) - one front, one rear. They attach via a plastic arm to right side lower control arms. In my case, I had inadvertently FLIPPED the control arm mounting point UPSIDE DOWN (it was a nightmare job).
Here is the INCORRECT Mounting (upside down):
Here is the CORRECT Mounting after I fixed it this morning (took about 5 minutes - there is only one screw that holds it there):
Now, I will have the dealership address the second issue (broken headlight). As qaz996 notes, the headlights are held in place with a couple of plastic stakes. The stakes go through the body of the headlight assembly (note: that would be the $1200 EACH - Xenon - headlight assembly), with the inner slot being the one that breaks. It has a u-shaped plastic loop that sheers off. This has happened on our car on the DRIVER'S side (left) headlight. This is a bit unusual as it is the RIGHT side headlight which gets removed routinely for oil changes. As a side note, they are the easiest to remove headlights in the world...they just have a stupid weak link with the plastic loop.
Now per, the TSB (TJ 27277) issued on Feb 26th, 2013, Volvo has a repair kit for this issue ( basically, a metal bracket (part # 31395688) which is bolted to the broken headlight to replace the missing plastic). The TSB ALSO notes that an improved headlight was introduced in "week 48 of 2012". I don't know what the new unit looks like - likely the same style but with some reinforcement in this area. Regardless, here are some pics from the TSB on the repair procedure so you know what I am describing:
See this thread for other info:
http://forums.swedespeed.com/showthread.php?205727-Don-t-change-the-oil-in-your-XC60-T6-engine-or-how-to-get-dealers-to-blame-each-other&highlight=headlights
Test drive confirmed the issue appears to be fixed. Will get the dealer to rerun any calibration procedure when I take it in to have the driver's side light fixed.
Mercedes dealer made that mistake on my old car too.
1 - 8 of 8 Posts
