after hours of getting pissed off i just decided to drill a hole to route the tube. worked great. poked a hole in the back side of the door wire harness rubber thing, and then ran it into the fender and then into the engine bay.
There's a rubber grommet on the passenger side. I drilled a hole through it and routed behind the glove box
Sent from my iPhone4S using Tapatalk while on the toilet.
That seems complicated. Behind the glove box would have been easiest I think.
The rubber grommet on the Pass. side comes out behind the glove box. Then you have to route the hose under the dash to the drivers area (Not that hard). Most difficult part is getting the hose through the grommet into the cabin.
Agreed! I spent a good 20 minutes just trying to get my hose behind the battery and into the cabin. I got really lucky with the route I took, I had a full 2" of tubing left. Talk about cutting it close!
